Toshiba Chromebook 2 will not run on battery power.
Toshiba Chromebook 2 will not run on battery power even though the battery indicates fully charged.
Is dit een goede vraag?
First how old is the computer? Do you keep it plugged in all the time? The battery could be ran down or have a bad cell. I would start off by replacing the battery with a new one, or barrow one from someone that will work on just the battery swap out the batteries and see if it will then. Most likely the battery will need to be replaced.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 40
