Ga door naar hoofdinhoud
The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
Toshiba Chromebook 2 will not run on battery power.
Toshiba Chromebook 2 will not run on battery power even though the battery indicates fully charged.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
First how old is the computer? Do you keep it plugged in all the time? The battery could be ran down or have a bad cell. I would start off by replacing the battery with a new one, or barrow one from someone that will work on just the battery swap out the batteries and see if it will then. Most likely the battery will need to be replaced.
Was dit antwoord nuttig?
Voeg je antwoord toe
Gene zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 9
Altijd: 74
