Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Is this display connector broken?
Can anyone tell me if this display connector is looking good?
The display brightness is not working correctly. I use a cheap eBay replacement display so before I order a new one I want to know if this connector looks good.
The 6th pin on the top looks weird to me..
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
For me, it's rather difficult to tell by just looking at this picture. Check carefully with tweezers if there is any unstable pins, which features poor contact with board.
It would be better if you have a multimeter to test the diode value of each pin on the connector. If it’s all normal value, then restart with a new display.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks! Will try to use tweezers and/or check with a multimeter.
door
Het nuttigste antwoord
Looks okay, might need to clean up the connector a bit on the 6 pin. 99% isopropyl alcohol and some brushing should get that cleaned.
Otherwise be extremely careful with tweezers / exacto knife to clean that out without damaging the pin.
Score 1
1 Opmerking:
Thanks for your comment. I've tried cleaning it with IPA two times but that didn't work. I will try to remove it with a tweezer.
door
Voeg je antwoord toe
Matthijs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 45
