Ga door naar hoofdinhoud
Smart fitness watch via Bluetooth, released in March 2016. Model: FB502SBUL
20 Vragen Bekijk alle
Fitbit Blaze only works in charger
My Fitbit Blaze works fine in the charger but shuts off immediately if the charger is unplugged or the watch is taken out of the charger. Can’t even reset using the reset procedure from Fitbit as there is no power at all. Shows 100% when in the charger. Is the battery a realistic possibility? It can’t imagine it is but the alternative sucks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
If it works on the charger but not when on the battery only, then most likely the battery has failed and needs to be replaced.
Here’s a link to the ifixit Fitbit Blaze Battery Replacement guide, which shows how to replace the battery.
ifixit sell a battery for the watch. Here’s a link Fitbit Blaze Battery
There are also other suppliers that may suit you better. Just search online for LSSP321830 to get results.
Replace a 170 mAh battery compatible with the Fitbit Blaze smartwatch. 3.7 Volts (V). Afbeelding
Product
$19.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Chris Chandler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 5,348
