Ga door naar hoofdinhoud
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
263 Vragen Bekijk alle
Charge indicator blinking orange, will not power up
I'm having this problem and I heard something about a internal fuse could of have blown. Could be a cause?
Is dit een goede vraag?
Score -1
1 Opmerking
There is a fuse on the power board that can cause this. You are putting this as an answer to someone else's question. Please ask your own question so that your problem can get the attention it deserves.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
A loose or defective battery can cause this symptom. Check the battery connector is securely installed onto the circuit board. This GUIDE may help
Was dit antwoord nuttig?
Voeg je antwoord toe
Eric zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,254
