Ga door naar hoofdinhoud
The 5th generation 2011 Explorer bore similarity to the Explorer America concept's construction, and includes a unibody structure based on the D4 platform.
18 Vragen Bekijk alle
Ac blower goes high and low by itself
What could be the proble? I set the fan to low and it will go high and low by itself!!
Is dit een goede vraag?
1 Opmerking
Navigation default activé en même temp que le blower goes high and low ????
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @velezgmario ,
It appears as though the blower motor resistor may be starting to fail.
Once it fails completely then the fan will only work on the high setting.
Here’s a link to a video that shows how to replace the blower motor resistor in a 2006 Ford Explorer. Not your model I know (couldn’t find a video for your model year range) but hopefully it is still good enough to be of some help.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Mariano Velez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 23
Altijd: 507
