Ga door naar hoofdinhoud
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Vragen Bekijk alle
Why my phone randomly shot offs after battery replacement bought here?
I recently changed my tmobile Note 5’s battery with the kit I bought from ifixit. I calibrated the battery after I install it or atleast I tried. I used the phone for couple of days and thought it was fine but later my phone started to shut off randomly and mostly below 50% battery. So, I guessed I didn’t calibrate the phone correctly and try to calibrate again (drain below %10 and full charge).
Long story short, nothing works still random shut offs. At this point I am wondering if the battery I got is compatible with my Note 5 (T-Mobile N920T)
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It’s a bad battery. I would go for another supplier such as Injured Gadgets / Mobile Defenders. Try getting a replacement one from iFixit as that is covered under warranty.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks, I contacted and waiting for their response.
door
Try calibrating your battery. When you get that new battery, look at this page. Battery Calibration
1 Opmerking:
It was a bad battery I got a replacement and it works perfectly since February
door
Voeg je antwoord toe
MR AD zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 61
