Ga door naar hoofdinhoud
De Xiaomi Mi A2 (wereldwijd ook bekend als de Mi 6X) werd in juli 2018 door Xiaomi uitgebracht in verschillende interne geheugenconfiguraties. Het toestel maakt deel uit van het Android One-programma, wat updates voor twee jaar garandeert.
Backlight only works during startup
I recently changed the screen on a Xiaomi Mi A2 Lite. When I start the phone up, the Android One logo displays with full brightness and colour without any issues.
The problem is that once the phone turns on there is no backlight. You can still see the display if you are in a dark room and everything seems to show correctly. I have tried updating and factory resetting but still having the same problem.
Any advice would be much appreciated.
Is dit een goede vraag?
Score 1
3 opmerkingen:
Did you ever find an answer to this issue? My phone developed the same problem yesterday.
door
I have the same problem with a replacement screen. Did you find any solution?
door
Have you found what was causing this?
I’ve the same issue, replaced the lcd on a xiaomi mi a1 and the backlight is present at the logo startup but completely black after that.
On a dark room I can barely see the screen and all it’s working, but adaptive light button is missing, seems like the bootloader is able to use the backlight but not android itself
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
I’d try to disable the “adaptive brightness” feature under settings->display, but I highly doubt that this can solve an issue like this.
On the software side there should be restrictions in place to how dim the screen can get and I’ve never even heard of the software having the permission to turn the backlight off.
The only suggestion then would be to replace the screen, but since the backlight is working upon boot…
Was dit antwoord nuttig?
Voeg je antwoord toe
Ryan Storey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 1,377
