Ga door naar hoofdinhoud
1,7 GHz dual-core Intel-processor (Turbo Boost tot 2,6 GHz) met 3 MB gedeelde L3-cache
Sudden screen glitches & freezes, requiring force restart
Hello!
My 2012 MacBook Air (I have the 2.0 GHz dual i7 + 8 GB of RAM model) has, for the last few months, started crashing at random, requiring a force restart.
Out of nowhere, the screen gets glitchy ~ you can see what was there, but its colors & shapes distort. If any audio was playing, it also becomes just a glitchy (loud!) mess. The only solution is to hold down the power switch for 10 seconds and force a restart. Or sometimes it restarts on its own after a few seconds.
The troubleshooting I’ve done:
1) installed a clean OS (Mojave) on a separate partition. Still happens.
2) happens on both battery & two different AC power adapters.
3) happens with & without external peripherals connected (powered USB3 hub, audio interface connected via firewire-thunderbold adapter).
4) I’ve reset PRAM & SMC. No help.
5) happens under heavy & light workloads, even sometimes sitting idle (i’ll return to my desk to find it has restarted itself).
6) sprayed compressed air inside all vents in case something was blocked by dust causing overheating. No help.
7) Ran Repair Disk in Disk Utility after starting up from recovery partition. No results.
What I haven’t done: replace the battery, which reports “Replace Soon”. I don’t want to throw big money at the machine if its logic board is about to die.
Any thoughts? The machine (aside from random crashes) still suits my needs perfectly, and I’d really like to not have to replace it.
Thanks in advance!
~ Peter in Athens
Update
Adding screenshots of CoconutBattery, per request!
Afbeelding
Afbeelding
Is dit een goede vraag?
Score 1
6 opmerkingen
First I would install this app to see more clearly whats happening with your battery CoconutBattery past a snapshot of the main window so we can see it as well Voeg afbeeldingen toe aan een bestaande vraag
door
I have the same issues with a fresh battery. The symptoms are exactly like described in the original post. Same computer. Very difficult to replicate as I’m not sure when it occurs. Have been keeping a log of circumstances under which this happens but there seems to be no red thread at all. I’m at loss over what other cause this could have.
door
@damianwinters - Best to create a fresh question with your details
door
I am having the same exact issues on a 2012 MacBook Air. I was originally on Catalina, then I decided to do a fresh install of Mojave, everything looked fine, until I experienced the infamous screen glitching and restart.
My battery has been chanced 3 years ago, but I must admit it's been used quite a bit. In Sys Info shows 360 cycles.
Do you guys have any sort of update/solution found in the meantime?
door
@manuele - Best to create a fresh question with your details
door
1 commentaar meer tonen
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
From the sounds of it you may have a failing drive issue as well. But before you can address that you really need to get the battery issue fixed first. Once we see the CoconutBattery snapshot we can guide you on whats needed.
Update (02/01/2019)
You’er running on borrowed time! Determine battery cycle count for Mac notebooks You battery has a lifespan of only 1000 cycles you’ve exceeded that by almost 500!
You’ll need to replace it first, here’s the needed part MacBook Air 11" (Mid 2011-Early 2015) Battery and here’s the guide MacBook Air 11" Mid 2012 Vervanging van de batterij
When the battery gets to this level its power output is not stable which can cause instability like you are seeing.
You should also rethink your usage pattern. You really don’t want to let the battery get to low before charging it up. Once you get down to 1/4 of the charge you tend to burn a cycle.
Replace a 5100 mAh battery compatible with the MacBook Air 11" Mid 2011 to Early 2015 A1370 and A1465 model laptop. 38.75 Watt Hours (Wh). 7.6 Volts (V). Battery model A1495. Afbeelding
Product
$49.99
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thanks Dan! I've added images of Coconut Battery to the Original Post.
door
thank you for the answer Dan! I'm just wondering though, since I'm seeing this behavior also when running on AC power... does this instability due to battery failure truly persist when running on AC?
Can you think of a way i can test this before dropping $100 on a new battery? If I take the old one out and try running only on AC, perhaps?
door
Surprisingly Yes! Your system will use both power sources. The dominant one is the battery.
If you disconnect the battery and the MagSafe connection is clean & stable you should be able to run your system without it crashing.
door
thanks so much for your help. i'll find a pentalobe driver somewhere and give it a try & report back
door
Voeg je antwoord toe
peter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,420
