Ga door naar hoofdinhoud
The Acer Aspire One D270-1865 was released in 2012 by Acer Inc. as apart of the Acer Aspire One series of netbooks.
Why is my screen not show
My screen is not show in my notebook.!!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @harimurari ,
Things to try:
With the laptop turned on, press Fn + F6 (both keys together) to check if this turns the screen on
Connect an external monitor to the laptop and check if it shows a display.
(even a TV if it has HDMI ports and you have the appropriate cable to connect between the laptop and the TV can be an external monitor) press Fn + F5 (both together) to toggle between the laptop screen, the external monitor and both screens together.
Try shining a torch at an angle close to the laptop screen to check if you can detect an image at all.
If you can you have a backlight problem. This could be caused by either a faulty video cable or a faulty screen.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Hari Murari zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 314
