Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy Tab 2 10.1 is een 10,1-inch Android-gebaseerde tabletcomputer en behoort tot de tweede generatie van de Samsung Galaxy Tab-serie.
Upgrading to latest Android version manually
Hi there, I have an old Samsung Galaxy Tab 2 10.1 with Android version 4.0.4. Nothing is compatible with it anymore. How can I upgrade it to the latest Android version please? I have checked and it says no updates available
Is dit een goede vraag?
Score 47
7 opmerkingen
Thank you so much
door
Yes, you can upgrade to Android 6 Lineage 13.0, I have Samsung tab 2 10.1 with that
door
Thank you so much Stephen. Much appreciated. How did you upgrade please?
door
I have samsung tab 2 and playstore dont want to work
door
I too have a Samsung Galaxy S - model number SM-T800 - running Android 6.0.1
When I check the updates it says it is up to date.
I would like to download an Application - Imaging Edge Mobile from Sony, so that I can check photos and videos taken on my Sony camera HX60V - It says the software is not compatible and I require Android version 7 at least to install the software.
How can I update the Android Version on my tablet?
door
2 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
here you go
you need to install a custom rom
Android is modified by the manufacturer to work on their device, because every device has different hardware.
https://www.youtube.com/watch?v=7V5tZi5V...
Was dit antwoord nuttig?
Score 8
4 opmerkingen:
I have two Tab 2's - both at now too slow to use. Wanted to see if there was a way to update. the link above is marked Private.
door
This was rubbish. The video whizzed through so fast and without explanation so that it was impossible to follow.
door
the video has gone private
door
As others have said, the video is private.
door
If you go to [http:// https://forum.xda-developers.com/t/how-t...|XDA’s website] by clicking the link it should bring you directly to the how to’s of the tab 2. there is all kinds of valuable info on this site and if utilized will hopefully give you a better understanding of your gadgets. Good luck!
Score 3
1 Opmerking:
Thank you William. That link was incredibly helpful!
door
Try googling (samsung android tab 2 update ) and it will tell you how and where to go
Score 1
Voeg je antwoord toe
Jackie Barton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 194
Altijd: 85,461
