Will I need a converter box to Proceed
I bought this TV years ago and has been stored away. Will it need a converter box of some kind to operate ? No channels at all in memory with antenna…
Is dit een goede vraag?
Hi @dmcq1964 ,
Here’s a link to the owner manual for your TV.
To receive digital OTA (Over the Air) TV signals using an antenna you need to connect the antenna lead to the ANT-DTV connector on the back of the TV.
Here’s an image taken from the user guide that shows where the connection is and also the conditions associated with connecting to digital cable TV if that’s what you want to do.
(click on image to enlarge for better viewing)
Also in the Setup > Antenna Menu area you need to select DTV and AIR if using an antenna or DTV and CABLE if your cable provider supplies an unscrambled signal that can be directly inputted to the TV
Here’s an image from p.46 in the manual showing the settings etc.
Was dit antwoord nuttig?
The back has a CATV input jack. If you are running cable TV just run a cable (Coaxial Cable) from your cable box to the TV and run the cable setup from the menu.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 966
