Ga door naar hoofdinhoud
Uitgebracht in augustus 2016, geïdentificeerd als modelnummer XAV-AX100 AV-ontvanger.
Power surge to volume
Whenever I open the door, step on the accelerator, or connect to the bluetooth. The volume goes to Max all by itself. Also if I just have it on for awhile it will do it I have rewired outside checked relays in grounds in the vehicle. Also replace fuses, Any other ideas
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Try removing all the radio's connections except the main wiring harness. If the problems stops, then it's likely an issue with one of the other connections such as the wired remote input. The Sony XAV-AX100 has a wired remote input intended for steering wheel control and it's possible that connection is acting wonky. Loose or incorrect connections at other inputs such as Sirius, mute, mic, remote turn-on, etc. can cause the radio to act weird. Take a look at the buttons on the faceplate and the remote to see if any are stuck or jammed.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jonathan Symmes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 316
