Ga door naar hoofdinhoud
Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
What do I try next?
My 2006 murano is running like crap. Engine light is flashing, shudders, abs light is on and the gas mileage has dropped significantly.
Had the oil changed, new plugs answer coil pack on #3. Didn't help.
Update (01/24/2019)
I did. It still has misfire #3. The plug has oil on it after one day of use.
Is dit een goede vraag?
2 opmerkingen
Hi,
Get the OBDII port scanned for any codes which may tell you what is going on.
I've read that in the USA, AutoZone will do this for free.
door
There isn't any smoke... (yet). The car is still in the shop. So far, I've spent over $500 and now the mechanic says he is waiting on the gasket to come in. I'll keep you posted. Thank you.
To be continued. ....
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Do you get blue smoke from the exhaust as well?
Here’s a link that describes the possible causes for oil to be in the spark plug well.
Scroll down to the section headed Common reasons for this to happen:
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Well, the car is fixed. It was the valve cover gasket. It was an expensive gasket, $262.64 + $55.00 for the ring part, but it's fixed now. Thanks for your help.
door
Hi,
Thanks for the feedback.
Drive safe.
Cheers
door
Voeg je antwoord toe
jennymcbly zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 10
Altijd: 229
