Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Screen issues after battery replacement, screen film stuck to battery
Replaced the battery and the screen was acting jumpy. I reopened the case and the film on the backside of the screen was stuck to the battery. Is this the problem and if so, how do I fix? The film is now bunched together and I cannot unbunch it.
Is dit een goede vraag?
1 Opmerking
Has the screen ever been replaced on this phone before? It sounds like someone installed a replacement screen and forgot to remove the protective layer.
The easiest way to tell is to attach a picture to your question.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
What do you mean film on the back of the screen. There should only be a metal
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
There is a very very thin piece of gray/black film that was attached to the backside of the display internally, and that is what peeled off by sticking to the battery which it was touching.
door
Is there a metal plate on the back of the screen
door
Voeg je antwoord toe
Sandwah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 59
