Ga door naar hoofdinhoud
De Samsung Galaxy A7 (2017) is een smartphone uit het middensegment van de Galaxy A-serie. Hij werd in januari 2017 door Samsung aangekondigd, samen met de Samsung Galaxy A3 (2017) en A5 (2017).
Multiple issues with SM-A720F (A7 2017)
Hello
I've got a notification for a newer version of Android available for my mobile. So I just downloaded and installed it. Everything was fine until I saw my screen is freezing.home and back buttons work but but when you touch the screen nothing happens. I have to lock and unlock the screen to use my phone for seconds then it freezes again. This happened in some last updates , then I use Wipe Cache Partition and the problem was gone.
but this time I use WCP and nothing happens. You can see here.
So I decided to download the previous firmware and android 6 & 7 firmware from Sammobile and install it using Odin. I am sure that these firmwares are for my phone , I checked everything. but then I see a "complete(write) operation failed" error and FAIL! in Odin for all the firmwares. after seeing this error I try for a second time , but then it just keep showing me the SetupConnection and nothing happens. Any ideas ?
thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
U need to check security level when u down grade firmware it most be same
Was dit antwoord nuttig?
Voeg je antwoord toe
Nader zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 856
