Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
#2 ribbin that it connects to chipped
I was replacing a digitizer on a lower dead strip iphone and when i was reconnecting the new digitizer the little white chip the connector number 2 slides into a little piece chipped out off... how i dont know but everything worked fine i continued but now when i get a call i cant hear over the earpiece and im wondering if that chip could be the reason or is their an earpiece issue and is this fixable or do i have to replace the whole board
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
no.3 is for earpiece/proximity and is the connector that slides in to the connection. just recheck that it is in all the way. my phone works perfectly without the tab that holds it in..
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Now what if the chip is where the no. 3 ribbon slides into
door
can you put a photo of the area in please? you may be able to create something to apply pressure to the area when the connector is in place..something like a piece of thin foam or cardboard.
door
it was one of my customers phones i will i found images of the peice i am referring too but idk how to post images to this site sorry im new since i needed help with this situation
door
far bottom left of the screen....big blue button.tbh i never see it and struggle to recall how its done!
door
Voeg je antwoord toe
joe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 637
