Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
20 Vragen Bekijk alle
How to fix a cracked screen
I have an iPhone 6 phone. The phone has been dropped and has severe screen damage. Although the screen is damaged, the screen still works and the digitizer appears to be working.
I don’t know whether the ONLY the screen should get replaced or both screen and digitizer. Again, it appears the digitizer is ok and only the screen has been affected by the drop. I would like to repair it myself, if possible.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Easiest way to do this is to just replace the entire display assembly. Replacing the Digitizer only requires special equipment and skills.
iPhone 6 Screen
iPhone 6 Vervanging van het scherm
Replace a screen compatible with iPhone 6.  Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 4.7 inch 750 x 1334 pixel IPS LCD Display. Afbeelding
Product
iPhone 6 Screen
$44.99
Was dit antwoord nuttig?
2 opmerkingen:
Thanks for the response. You suggest I should replace the LCD screen and digitizer? Which is the whole assembly.
door
Yeah because it requires special tools and skills to replace just the digitizer.
door
Voeg je antwoord toe
jkbmjp zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 85
