Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
20 Vragen Bekijk alle
iPhone 7 Plus doesn’t charge
Hello
I currently have a iPhone 7 Plus, Which has been working fine up until today, I turned the phone off as usual before I went to bed, Woke up, Went to plug it in for a charge, And nothing happened. I immediately thought it must have been the cable (Genuine Apple cable that came with the phone) So I went to Apple to purchase another plug and cable but unfortunately the same issue still persists.
I’ve had the phone for a year and half so no Apple care or warranty unfortunately.
I’ve tried the usual, Clean out lightning socket, Hard reset, Erase, etc etc even tried DFU mode in the hope iTunes might recognise it, But still nothing, Has anybody got any suggestions? I personally don’t think it’s the battery, What about a charge port replacement?
When the phone is off and I plug it into a charger it will power on but just won’t charge.
Im pretty much scratching my head on this one.
Is dit een goede vraag?
1 Opmerking
I have an iphone 7 plus too but when its screen was cracked it died and doesnt turn on now. I might be using a cable that is dead or too weak.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You say you had a genuine Apple cable, was the same true for the charging brick? Do you use any “cheap” car chargers ? Dollar store chargers can damage the charge circuit inside the phone.
If you have used nothing but original chargers and cables, it is still possible the charge circuit failed. However, before that you must eliminate modular failures (battery/Lightning Port). You can do this yourself or bring it into a shop so that they can very those components for you.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Yep the charging brick was the one that came with the phone, Nope never had a need for a car charger the phone can usually last me all day till I home from work so only gets charged at home.
door
It’s very possible it could be the battery. But there is a chance it could be the charging port also. If you’ve had problems charging the phone before (It will charge to 100%, instantly drop down to 40% after being off the charger for around 5 minutes, and then die) it’s possible it could be the battery. If when you plug in your phone and it will not show that it’s charging at all, then it’s possible it could be the charger, or the charging port. I would recommend trying a new charger before getting a charge port replacement.
If you would like to replace the battery yourself here is a step-by-step tutorial, along with a new battery :
iPhone 7 Plus Vervanging van de batterij
iPhone 7 Plus Battery
If you would like to replace the charging port yourself here is a step-by-step tutorial, along with a new charging port :
iPhone 7 Plus Lightning Connector Assembly Replacement
If you bring it into a tech shop that can fix it for you, they should be able to “Open test” a new battery and/or a new charging port. Which means they can open the phone and test to see if either you need a new battery, or a new charging port.
iPhone 7 Plus battery replacement kit. 100% factory tested, 2900 mAh high-quality battery. No soldering required. Compatible with all iPhone 7 Plus models (not iPhone 7). Afbeelding
Product
$29.99
Replace a lightning connector, two microphones, and cellular antenna compatible with the iPhone 7 Plus. Fix problems with charging, USB device connectivity, and audio recording. Part #821-00276-05. Afbeelding
Product
$24.99
iPhone 7 Plus Batterij Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 2 hours
iPhone 7 Plus Lightning Connector Assembly Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 - 2 hours
Score 1
3 opmerkingen:
Hello, I did this and the iPhone is still not showing anything. Any ideas?
door
@mathilda3915 When you say you "did this", do you mean you replaced the battery, the charging port, or both? You tried a new/different charger and/or cord too, right?
door
@dadibrokeit yes both, different cables and chargers too. still black screen and nothing shows on the computer either.
door
Voeg je antwoord toe
g.breslin91 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 77
Altijd: 5,990
