Bluetooth not working on Dell Latitude E6430
On my Dell Latitude E6430 (Windows 10 Home x64 ) I cant find a setting for Bluetooth. In the BIOS Bluetooth is enabled. When I try to install drivers it says activate Bluetooth using wireless switch, but the switch is on.
Is dit een goede vraag?
2 opmerkingen
Hi,
What is the status of the Bluetooth adapter in Device Manager?
Right click on Windows start button and select Device Manager > Bluetooth
If it is not listed click on View > Show hidden devices in Device Manager and check if it now appears.
Have you tried Windows Troubleshooting to check if this resolves the problem?
Go to Control Panel (click on Start button and then type Control Panel in the search box and select the Control Panel app option) > Troubleshooting > Hardware and Sound > Bluetooth
door jayeff
Hello,
When I pressed show hidden devices Bluetooth showed up b ut when I clicked Dell wireless 380 Bluetooth module it said"to fix this problem, reconnect this hardware device to the computer."
When I go to the control center there is no Bluetooth option.
door Panayiotis Michalos
