Ga door naar hoofdinhoud
Shark Ultimate Professional 1800-watt clothes iron, identified by model number GI505.
Why does my shark iron temp setting light keep changing?
My shark iron is only 4 months old. When I set the temperature control light, it will not stay set. It runs up and down and may even turn itself off.
Is dit een goede vraag?
1 Opmerking
My iron does the same thing and has done this since Day 1. The steam doesn’t always work either. I thought it was something I was/wasn’t doing right. I’ve had my iron for over a year.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @littleproblems ,
It appears that there may be a problem with the temperature sensor in the iron.
There is a 12 month manufacturer’s warranty on the iron.
As the iron is only 4 months old, I suggest that you contact the manufacturer as per the details in the manufacturer’s warranty statement that should have come with the iron, as to what to do to make a claim for a manufacturer’s warranty repair or replacement.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Sherall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 1,311
