Ga door naar hoofdinhoud
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 Vragen Bekijk alle
Can I use the glass and battery from a mini 2 on a mini 1
I recently found a iPad mini 1 in a recycling center. The battery is a bit bloated and the glass is cracked. Can I use the glass and battery from a mini 2 to fix the mini 1? I dont need the LCD just the glass. Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Ethan, yes you can, the IC chip is the same one from the iPad Mini 1. Therefore, you can use the glass. However, the battery is not compatible.
Was dit antwoord nuttig?
Voeg je antwoord toe
Ethan Leroux zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 471
