Ga door naar hoofdinhoud
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Vragen Bekijk alle
Why do I have to open my computer several times?
My computer crashes frequently. And everytime I want to open it it makes a beeping sound. I have to open and close it several times till I get the home screen. And when I work on it for a bit, it crashes and sometimes makes repeated beeping sounds. Can anyone help me? One of my 2GB rams are not being detected could this be the reason?
I had someone install 2 new pairs of 2GB rams and it did the same thing even though both Rams were detectable. Does that mean I need to upgrade my Rams to 4GB each or is the problem elsewhere?
Is dit een goede vraag?
3 opmerkingen
Can you give us a better idea on the tones. Review this Apple T/N About Mac startup tones
door
For those asking about the type of tones. In most cases it is one long tone as I open the MacBook. This normally happens to me every time I open the MacBook and when it crashes it causes the long tone.
There are times however when the MacBook crashes it can causes a repeated shorter tone that happens every 5 seconds both after it crashes directly and when I decided to open it again. This phenomenon is less frequent than when I get long tones.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your EFI chip is damaged:
  • One long tone while you hold down the power button: An EFI ROM update is in progress. This applies to Mac computers from before 2012.
If you are getting this over and over again the update is not able to complete. I suspect your system was also running Windows and under it a BIOS malware was downloaded that is preventing the system from updating. You will need to find someone with the needed skills to replace your EFI chip and you might need a new logic board given the other tone error which implies you have a RAM error thats more likely a bad socket.
  • One tone, repeating every five seconds: No RAM is installed. If you recently replaced or upgraded your computer's RAM, check to see if it was installed properly.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
What update are you referring to in this case ?
door
The OS Update process - During the process the EFI malware definitions are updated as well as any other firmware updates like support for APFS boot volumes.
door
Voeg je antwoord toe
Mohamed Ghoneim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 66
