Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2692 Vragen Bekijk alle
Is it possible to get under 100% max cap after a battery replacement?
I replaced the battery of my iPhone 6S. It had 75% max cap. and my question is if it is possible to get under 100% after a battery replacement cause I don’t want to replace it again.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Max capacity will always deplete over time. The aftermarket batteries will drain and deplete faster so make sure to get the battery replaced from a reputable store or buy a good quality battery.
Was dit antwoord nuttig?
Score 2
check this post [iOS 11.3] Battery Health Beta - No Change after Replacing Battery
2 opmerkingen:
That isn’t what I was looking for but thanks.
door
if you read it all there are some solutios. In your case if the battery you bought is bigger(more mAh) can be the reason. Or if it is not certified apple battery
door
Voeg je antwoord toe
Ruben zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 67
