Ga door naar hoofdinhoud
De iMac G3 was verkrijgbaar in de kleuren tangerine, blueberry, lime, grape en strawberry.
iMac sortof powering up
My iMac G3 was working but now isn’t. It’s exhibiting bizarre behavior so I’ll be specific. When I plug it in I can hear a faint high pitch whine from the inside. Pressing the power button results in it glowing amber, the hdd spinning up, then the bootup chime. The display does not come on. Shortly after the chime there will be a sort of thunk then the power button will turn green within a blink of an eye the whole thing shuts off. It won’t even think about showing signs of life afterwards. The only way to repeat this is to leave it unplugged for an amount of time. When I plug it without doing anything else the lights will slightly flicker so I think something is happening.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
The first thing I would do on this one is the put in a new 3.6 volt 1/2 AA PRAM battery. To do that you need to pull the logic board. Here’s the guide. You can see that battery on step #8 of the guide, sitting right on top in the middle.
iMac G3 Model M4984 Logic Board vervangen
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Owen Davis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 15
Altijd: 355
