Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Vraag afgerond
Soldering the LCD connector
Hi,
what temperature should i use to solder the pins on the LCD-connector (1). The former owner pulled a little bit to hard, now some of the pins are...lets say disconnected.
I use a WELLER EC 2002 with a very fine tip and i already looked for a new LCD. So why shouldn´t i try to solder it, its ruined anyway.
Is dit een goede vraag?
1 Opmerking
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it from the unanswered list. Thanks.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
I wanted to solder the connector back to the cable of the LCD. I've tried it with 320°C but that didn't worked. A day later the new LCD arrived so i didn't tried it anymore.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
The temperature has to be above 320°C...just to get it off the unanswered list.
door
thanks
door
I am not clear on what you are soldering. The connector that the LCD plugs into on the logic board?
spam
1 Opmerking:
all your answers are just links to a pay service...
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 4,511
