Ga door naar hoofdinhoud
Budget 15" laptop series released by HP.
261 Vragen Bekijk alle
Any teardown video of the HP Spectre x360 15t?
I recently bought the new HP Spectre x360 15t Model# 15-df0008ca.
Very stunning laptop. I am very impressed of the overall performance and design. Also, it feels and look durable.
I am curious of how the components may look inside or of a similar model.
I took the risk knowing it might not be a replaceable RAM. It should thought?
See more spec information below:
https://www.bestbuy.ca/en-ca/product/hp-...
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi @sirdre ,
No video but here’s a link to the service manual for your laptop, taken from this webpage’s User guides link
On p.1 it states that the laptop supports up to 16GB of RAM.
On p.25 it shows the procedure to access and remove the memory modules. (see the warning note about updating the BIOS when changing memory).
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks. I am not ready to see for myself yet but soon. I appreciate the manual thought. Very detailed but seems somewhat similar to my own.
door
I managed to open my HP Spectre x360 15 (gem cut). Everything looks awesome. :) Except for the Wireless AC Adapter which seems to be soldered on. :(
Score 1
3 opmerkingen:
This is awesome. Were the screws under the rubber strip?
My 15-df0008t has a high pitched fan noise I wanted to open up and investigate. Do you experience this?
door
Thanks.
The screws are under that strip (Feels like a plastic material). Simply, lift strip to access fan screws and chip. Make sure you repasted the chips after you take the fan off.
I don't experience any high pitched fan noise at all even under heavy load. Probably some type of dust got caught in it. Use a dust spray - https://www.amazon.ca/dp/B007Z7OK3Y/ref=...
door
Hi sidre,
Which version your HP Spectre is? 15-df000xxx? Which configuration?
door
https://youtu.be/4Dk8Vz0Aah0 here's a video i found of the x360 15t
Voeg je antwoord toe
André zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 3,587
