Ga door naar hoofdinhoud
The DZ09 is a Chinese smart watch with basic features and the ability to make calls. These can be as cheap as $10! (Yes, you read that correctly!)
90 Vragen Bekijk alle
Micro SD Card will not read on watch, works on my computer.
I have a DZ09 Smartwatch I received a few days ago. The only problem is that it won’t seem to read SD Cards. I’m beginning to believe that the slot was dead on arrival, but I’ll ask here for answers. Yes, I have tried multiple SD Cards. They all don’t work.
Is dit een goede vraag?
Score 3
1 Opmerking
Anyway to solve the issue
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi @superdoggo ,
What capacity SD Card are you trying to mount in the watch?
According to this link the maximum supported size is 32GB. Just a thought.
If the cards that you tried were of equal or less capacity than this, then it may be as you said, the SD card slot is faulty.
As it is a new watch, consult the manufacturer’s warranty statement that should be with the documentation that came with the watch, as to what to do to make a claim for a manufacturer’s warranty repair or replacement.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
The capacity of the Micro SD Card is 2GB. It is from Sandisk. Also, I don't think I can make a warranty claim due to me ordering it from Wish.
door
Depending on your computer hit win+x then k and make a volume in sd card or ubuntu hit super key type gdisk and format there
You need to format the SD card in FAT32 format, exFat and NTFS will not work.
Voeg je antwoord toe
SuperDoggo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 4,954
