Ga door naar hoofdinhoud
Een tablet die kan worden aangesloten op een draagbaar toetsenbord om als laptop te fungeren.
bios not detecting hard disk
Ok, I have a Lenovo Flex 4 15" 2in1 laptop which I had two years but after the first year it would not fully load maybe because of connection, (maybe). Yes it will still power on. Now after some time I realized my Bios setup did not recognize are was not communicating with the hard disk . At first, thought hard drive was bad but it wasn't. Have anyone had this issue and can help me. Your help will be a blessing too me.
Is dit een goede vraag?
4 opmerkingen
When you turn on your computer, it show you a message like no hard drive detected ?
door
no just the name of my laptop
door
Have you tried to set default settings of the BIOS ?
door
when i go to bios it keep asking for password which i do not have
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Alternatively, you can try manual methods to fix this error, but if they do not help, then you need to change the Hard Disk.
Check the data cable
Check the Jumper Setting
Check for Auto Drive Detection
Check if the Drive is spinning
Generally, if the hard disk is not recognized by the BIOS, you have a hardware failure. For example, the Hard Disk is dead. In this case, you’ll need a new hard disk.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
WILLIAM WALKER zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 40
Altijd: 611
