Ga door naar hoofdinhoud
Repair documentation and service information for Hisense televisions.
126 Vragen Bekijk alle
Stuck on blue screen that says there is no device connected to tv
Hisense 50k360g. Only button that works is power button on tv itself. Just says “there is no device connected to tv!” I’ve tried unplugging and other things to no avail. Need help asap.
Is dit een goede vraag?
Score 6
7 opmerkingen
Hi @brady_hess ,
What "other things" have you tried?
Knowing this may have saved time and repetition.
What did you "unplug" and if it was the power for how long?
Have you tried a different signal source and connecting it to a different input type than normally used, e.g. connect a dvd player via the component, composite or HDMI connection (whichever one you are NOT using now) and see if that works?
door
This doesn't work
This doesn't work I tried it 5 times this is bull. I need an answer
door
I have the exact same problem
door
I cut off my game system and now it's just stuck on no media device Connected to tv. Help asap. It was just working
door
This just happened to me as well. No remote. I've tried a different source, doesn't work. I've tried to unplug it and let it sit to know avail. I'm starting to think this brand is junk! Getting frustrated.
door
2 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Turn tv on. Minute tv says hisense right when it's about to go blue hit the menu on the back of tv. You might have to hit the button couple times for it to come up on screen. It is the only way to fix the tv. Use the arrows and what not to get to channel where it says cable or antenna. If you mess with those enough you will get it back on. Trust me I just did.
Was dit antwoord nuttig?
Score 6
6 opmerkingen:
This was the only helpful comment. Worked for me first try. Thanks
door
This worked!!!! First try and it worked. I’ve been a week without TV and tried other options offered that didn’t work. This worked the first try. THANK YOU!!
door
What exactly did you guys do I tried calling Hisense and they were no help was so ever I finally got it off the there is no device connected to this tv but that’s as far as I got.
door
I only have a power manual button.
door
@tammysenio41568 this question has been floating around for the last 4 1/2 years. It'll be difficult for you to get the information you need. Let's start from scratch. What make and model is your TV? What does or does it not, do? What have you tried? What is going on with it? The more information you provide the more likely you are to get a helpful answer.
door
1 commentaar meer tonen
Hello..
Before you do anything you will be check your some things,
Make sure your TV receiver is on and your cable connected securely. May be your cable not connected exactly, I mean it can be loose. but if all these things is correct then pickup your remote hit the input TV audio/video button.
check if there is a signal coming in another source connected to your TV.
Score 3
2 opmerkingen:
I dont have a remote and its stuck on the blue screen. ? Help.plz
door
@Maria Garza
What is the model number of the TV?
Try connecting another signal source e.g. dvd player to the TV (HDMI or Component or Composite video connection) and then using the Input button on the side of the TV (if it has one) to change inputs to check if there is a display or not.
It may be that there is a problem with the signal source (is it a cable box?) and not the TV.
door
My Hisense tv is stuck In blue screen that says no devices connected
See answer above by April Brockman (March 2, 2021).
Voeg je antwoord toe
Brady Hess7 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 67
Afgelopen 30 dagen: 302
Altijd: 13,250
