Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de eerste generatie Apple iPad met 3G-mogelijkheden, beschikbaar met 16, 32 of 64 GB opslag. Uitgebracht in april 2010. Geïdentificeerd door modelnummer A1337.
How to run iPad without battery?
I bought an iPad with dead battery (it’s bulged). When I connect it to a charger, the only result is a boot loop (Apple logo, blink, Apple logo, blink…).
I want to use it as a kind of picture frame, which would necessitate constant charging anyway, so I’m reluctant to buy a replacement battery that will be of no use and dead again within few months because of constant charging.
Is there any way to forgo battery entirely? Some “fake” battery to allow it to boot?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
iPad is designed to run with a battery, thus there’s no really easy solution for your need. Not sure if the system requires also a battery presence acknowledgement or it’s sufficient a component bridging, but unless you’re able to microsolder and have the necessary tools is not a very handy solution. If you have to find and pay someone doing the job you’d end up paying multiple batteries cost to get the job done. All in all I believe a battery replacement is the easiest and cheapest solution.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Stan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 61
Altijd: 9,358
