Compatible audio jack replacement part?
I’m having issues with my headphone jack and want to try replacing it, but can’t seem to find a part specifically for the K550L. Would a jack from another K series be compatible? And if not, where would I find a good replacement?
Is dit een goede vraag?
Just curious if you have tried using rubbing alcohol on a q-tip to clean out the jack. Sometimes dust gets repeatedly smashed between the contacts and forms a film.
door Isaac
Thank you Isaac, I tried this as per your advice, and there was some dirt in there. However, it did not solve my problem, which is my computer will show a popup of "you just plugged in an audio device" when there are no headphones in, cutting off the speaker audio. (Additionally the headphones have to be in the exact right position for audio to come through clearly.)
door Aarin Miller
Update your device manager for audio devices and check if the popup problem is resolved. And for jack is it lose or tight if it is loose then you have to do some adjustment by tighten up the jack
door Amily Grey
Thank you Amily, I tried updating my audio drivers, but it did not help. Any advice on how to properly tighten the jack?
door Aarin Miller
