Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Replaced battery, now computer shuts down randomly
My battery wasn’t doing great so I replaced it with a battery from iFixit. Replacement went fine, battery was charging, but now, I can be working on battery power and suddenly the computer will turn off. Not shutdown, but a complete power pull. It’s as if the battery is suddenly not recognized. The first time this happened, I fixed it by opening up the case again and making sure the battery was properly seated, which it was. It has since happened again, and upon powered reboot, the computer doesn’t recognize that there is a battery there.
I’m at a loss as to why this is happening and would appreciate any assistance.
Is dit een goede vraag?
1 Opmerking:
Maybe the wires to the connector from the battery are faulty, like loose contacts. Check if all are firmly connected and or use a volt meter to check it
door
Voeg een opmerking toe
1 Antwoord
Dear Friend.
It happening because of the battery cant drive the laptop ( not getting enough current).
Just try another Battery. (first try cleaning connector pins)
i think it will fix
All the Best
Was dit antwoord nuttig?
Voeg je antwoord toe
Megan Sullivan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 138
