Ga door naar hoofdinhoud
Neato Botvac D80 issue.
I own 2 of these units (identical). By swapping a couple parts I have determined that the battery, and charger base are not the problem. Bad unit has no power at all. If I put it on the base to charge, Home button lights up green, tells me to turn the switch on (it’s already turned on, but I press ok anyways). Home button turns to amber (slow blink to indicate charging has started). After between 10-30 seconds, it changes to rapid amber blinking on home button and after about 3 seconds it shuts down, reboots and starts the process all over. Ideas?
Is dit een goede vraag?
Score 3
1 Opmerking:
Hi Jeff, got the exact same problem. Figured it had to be a faulty on/off button so I swapped it for a new one, only to find out that was not it...Did you ever find out what the problem was?
door
Voeg een opmerking toe
1 Antwoord
I just successfully repaired a Botvac D85 that had a similar issue. I connected my computer to the USB port and saw an error flash that said the battery was overheated. This caused the main board to automatically power off. The root cause for mine was the Fuel Gauge IC. It took a hot air station and some patience. You might give this article a look. http://www.robotreviews.com/chat/viewtop...
Was dit antwoord nuttig?
Voeg je antwoord toe
Jeff zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 1,100
