Ga door naar hoofdinhoud
The first model of the iMac line of personal computers made by Apple. The iMac G3 was produced between 1998 and 2003.
Having troubles with the G3
So recently I got my hands on a IMac G3, and I’ve been having problems with it turning on. To explain, whenever I hit the power button wither on the keyboard or computer itself, the crt makes the sound of a static discharge/piping sound, and the power light comes on and the edges of the screen light up ever so slightly. However right after turning it on, it immediately powers off, and if I try turning it on again shortly after. the crt makes a sound that’s comparable to a sqeek and powers off almost immediately. I did however replace the pram battery, but the computer is still doing the same things it was doing with the old pram battery. So I was hoping if someone could help pinpoint the problem or if my computer is long gone.
Fyi: Mac model is M5521
Is dit een goede vraag?
Score 2
1 Opmerking
Mac model is M5521
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The first thing I would do is replace the 1/2 AA 3.6 volt lithium PRAM battery. It is located on the logic board. See step #10 of this guide: iMac G3 Model M4984 Hard Drive Replacement
There is no guide for your M5521 model but these machines are almost identical except for the processors.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I have already replaced the battery, but it's still doing the same thing. Are there multiple batteries in the M5521 model? Or could I have placed it in wrong?
door
The battery cage usually has a + and - sign in it.
door
Voeg je antwoord toe
Joji zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 253
