Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
iPhone is very difficult to charge - what can I do?
My phone battery works well, but it is very difficult to charge. I have tried with several cables, and every time I find a cable which seems to work well, after a while it doesn’t work anymore either. Now I have one that I have to hold in a very specific position to allow it to charge, but I don’t know how long it will last. What do you suggest I do?
Thank you!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
change the dockconnector and your phone will work again
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
It seems your lighting cable connector on iphone side is expanded. use some tape on your pin and insert so that it can firmly hold inside iphone connector point
Score 1
3 opmerkingen:
Thank you. This is what I thought at first, but it is not effective. Most of the times attaching/inserting the charger more strongly doesn't have any effect.
door
as your cable is working so only issue is charging cable not properly fix into connector of phone side. Now find any way which can hold it firmly.
door
i dont think for such small issue you would like to change connector point.
door
Voeg je antwoord toe
Myrah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 46
