My 3 year old Toshiba - Model # 49L420L was having the same issue tonight :
ISSUE : Black screen, Red light on the tv indicator, when I tried to turn it on, it would flash the Toshiba logo and then show a black screen however sound was coming out still.
Note : Unplugging the TV, modem etc did not fix it.
HERE IS THE THING THAT FIXED IT -
- I unplugged my TV
- waited 30 seconds
- after the initial 30 seconds (while it was unplugged) I held down the power button for 30 seconds
- I plugged the TV back in.
- I held down the power button again for about 15 seconds + / -
- At this point the screen started to turn on by itselelf and went back to its typical green 'sleeping' screen saver and it worked just fine after!
Hope this helps everyone!
31 opmerkingen
Hi @meowmix7878 ,
Try a power reset and check if this resolves the problem.
Disconnect the power from the TV.
Press and hold the TV's Power On button for 30 seconds and then release. (the button on the TV not the remote control).
(If your model has a Power ON switch and not a push button, just switch it on for the 30 seconds and then switch it off)
Reconnect the power to the TV and switch it on to see what happens.
What is the model number of the TV?
door jayeff
The Tv model is Hisense it go's of and on showing the name of the Tv
door Ar Glyphikzzz
I need help please
door Ar Glyphikzzz
Hi @ Ar Glyphikzzz,
You need to supply the following information to get relevant answers.
What is the model number, not just the name?
Does the power light turn off or only the screen?
door jayeff
I tried all that what said to do its not working
door Ar Glyphikzzz
26 commentaren meer tonen
