Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
Unable to activate - error.
Trying to set up this iPhone 6s and I keep on getting this message.
Unable to Activate
An update is required to activate your iPhone.
I have put it into restore mode twice now into iTunes on my Mac and attempted to Update & Restore. Still coming back with the same thing. Haven’t tried just restoring but it’s saying it needs an update. Also has the small exclamation mark in the top left hand corner with a “No Service” sign next to it, even though it has a SIM in it.
Any help would be much appreciated.
— Sam :)
Is dit een goede vraag?
Score 36
13 opmerkingen
Iphone 6
Unable to activate
Solution
door
I have no clue how on earth is this website gained enough SEO To be this high up in this search there’s absolutely zero knowledge or advice on this page is absolutely useless
door
If you have a question, ask. If you have a better answer you're free to contribute, anytime. Criticism is always welcome, pointless whining is useless.
door
hi
i dont active my phone
after update whit itunse back again to unable to activate your phone page
door
i can't activate iphone 6s after update.unable to activate an update is recuired to active.please help me
door
8 commentaren meer tonen
Voeg een opmerking toe
11 Antwoorden
Het nuttigste antwoord
I think your phone not have IMEI now.... Check on Activision screen symbol “I “ ….. When you not see the IMEI is baseband problém... Without IMEI not possible
Was dit antwoord nuttig?
Score 12
5 opmerkingen:
@vojtech So, without the IMEI it's impossible to restore?
door
what do you mean that there is ni imei how is it possible
door
how imei not show in the iphone is it some things are missed or stolen
board
door
A fault in baseband circuitry is enough to have a phone being unable to provide the associated IMEI code. Nothing to do with a stolen board.
door
how solution???
door
Follow these steps:
  1. Check the list on the System Status page. If the box by iOS Device Activation isn't green, try to activate your iPhone later.
  2. If asked to enter your password as you activate your iPhone, enter the password. (A password prompt means that Activation Lock might be enabled in Find My iPhone.)
  3. Restart your iPhone (Skip since you have tried this method).
  4. If you're using a cellular data connection, connect to a reliable Wi-Fi network instead.
If you still can't activate, here's how to activate your iPhone through iTunes instead:
  1. Make sure that you have the latest version of iTunes.
  2. Check that your computer has an Internet connection.
  3. Open iTunes on your computer. With the cable that came with your iPhone, connect your iPhone to your computer.
  4. Wait while iTunes detects and activates your iPhone:
  5. If iTunes shows, "Set up as New" or "Restore from Backup," it means that iTunes activated your iPhone.
  6. If an error in iTunes says that the SIM card isn't compatible, contact your carrier.
If all of the methods not working, try to contact Apple Support.
Score 4
iUnable to activate related to baseband issues.If the phone fails to detect IMEI while on activating the phones.There is common problem shows on.The way of repair that problem
.1- BBPMU reball
2- Wtr problem
3- BBCPU reball
That need to hardware skill that can`t be fixed with software.
Score 2
Sim not valid iphone6s
Score 2
Here's a bypass to get more usability out of your device (not a complete fix)
https://youtu.be/3NSWsWeINC8
Score 1
My iPhone not activated no service
Score 1
1 Opmerking:
My iPhone no service problem not activated
door
Why showing unable to activate
Score 1
My iphone like this this for 1 week now i cant call nothing. and now i cant live.
my iphone 6s unable to activate
my problem is that my iPhone is saying unable to activate ,You iPhone could not activated because the activation server cannot be reached
You have to jailbreak it with ramdisk and create new apple id
Voeg je antwoord toe
Sam Mileberg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 54
Altijd: 34,220
