Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Half of the screen doesn't work!
Hi, so I dropped my iPhone 6 today and then later found out that the bottom half of the screen is unresponsive and doesnt work. I then went to several repair shops asking for a screen replacement but my phone is bent. Any way how to fix it? PLEASE REPLY.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The first thing you would try would be to check if the cables are correctly in place. Open up your phone, disconnect the battery, then unplug the screen cables and reconnect them again. The next thing you would try would be a new screen. Try replacing your screen with this guide iPhone 6 Vervanging van het LCD-scherm en de digitizer
Then, if that doesn’t work, then if would be a problem with the touch IC. You mentioned that your phone was bent. Can you see any weird grey bars on the top of the screen? That is often a symptom. Having a bent phone can damage the touch IC and display ICs, which stops the touch screen from working. If a new screen doesn’t fix it, I would suspect it is a problem with these ICs. It is a common issue in the iPhone 6, Bring it to a micro-soldering repair shop, and they should be able to fix this.
Was dit antwoord nuttig?
Voeg je antwoord toe
PSDara zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,331
