Ga door naar hoofdinhoud
Released in March 2016, the 80D is the successor to the 70D, featuring a newly developed 24.2 megapixel APS-C sensor.
What is this part of the LCD screen called? (Canon 80D)
Hi everyone, I recently dropped my 80D on the grass, it had the LCD screen open, and luckily, it keeps working fine, but now doesn’t let me pull it out, as the “rotating” part broke (see photo).
As the screen itself keeps working perfectly well, I was hoping maybe I could get somewhere just this “mount” part, instead of changing the whole thing?
Couldn’t find this replacement part or at leas it’s name anywhere (neither could I find the whole screen kit with this base). Could anyone help?
Thank you very much in advance,
Alex
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Looks like a compression fitting to me. Put the back into place and see if you can press it on.
Was dit antwoord nuttig?
Score 2
@geofocker that is simply called a hinge. Amazingly enough it does not appear to be readily available and when one can be found it is costly like on here
Score 2
1 Opmerking:
Thank you very much! It is, indeed, what I've been looking for. And yes, it seems a bit costly, but, will give it a try :)
door
Voeg je antwoord toe
Alex Krotkov zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 563
