Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Battery not charging after DIY repair.
Hi,
My wifi signals were very weak so I decided to replace wifi flex cable. Using ifixit app I read the tutorial and fixed it. I was quite happy but later on realised phone is not charging. I opened my iphone again and checked if all cables are attached and they were perfectly placed. I switched off my phone and connected charger it powered ON but again it wasn't charging. Please help me. And also tell me which cable transfer current to battery. Maybe,I would have dislocated something.
Is dit een goede vraag?
3 opmerkingen:
@aatif667 Do you have a computer running macOS/OS X handy?
door
Yes.. i have macbook pro
door
I put it on charge for an hour now its taking charge. But now comes the other problem. Touch and screen is working fine. But while powering off I can't slide that to power off.
door
Voeg een opmerking toe
1 Antwoord
iPhone 6 Vervanging van de batterij
Step 12 shows you the battery connector. Check that connector. You also could have damaged something in the process.
Was dit antwoord nuttig?
Voeg je antwoord toe
AATIF ALI KHAN zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 71
