Ga door naar hoofdinhoud
Why is my ram detected as 4gb when I have 8gb installed?
Sometimes the bios of my laptop detects the amount of RAM I have 4 GB and other times as 8 GB when in fact I have installed 8 GB of RAM. Could someone pls help me?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Try reseating the memory card. Here’s a link to the user manual for your laptop, taken from this webpage. Scroll to p.82 to view how to access the module (note the pre-requisite steps) and to remove/replace (i.e. reseat) the module.
Download and run a free memory test program to check if there are any problems with the memory module.
Was dit antwoord nuttig?
Score 1
Hi there, i asume it could be because of MHz of your rams. Check motherboard/computers manual, it should tell you supported tipes of rams
Voeg je antwoord toe
Priyadharshan Kannan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 354
