Ga door naar hoofdinhoud
The HP G62 is a laptop series produced by HP. G62 laptops are identifiable by the model number G62-XXX-XX, and endings vary depending on options and seller.
33 Vragen Bekijk alle
Blinking caps lock solid red wifi light.
It blinks every 4 seconds or so. Solid red WIFI light. No beeps. If I leave it on for a while or really any time it gets hot it boots like normal and has no problems until it cools down. Why is this happening? Is it time for a new laptop? Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
- Start by doing a hard reboot, remove the battery and unplug the AC adapter then press and hold the power button for 20 seconds then try booting it up again.
- If this will not work, do test the AC adapter if it's working properly. Remove the battery and power the laptop with just the AC adapter connected and see if it will boot up or not. do also try a different AC adapter that has the same voltage and see if it will work or not.
- Proceed with reseating the RAM's if trying a different AC adapter will not work, remove them all for couple of seconds then put them back in making sure everything is seated properly.
- If it will still not work, connect an external monitor and see if you'll get any display from it. If there's a display on the external monitor that could mean that the problem is the built in display.
- But if there's still no display on the external monitor that means the problem lies in the motherboard.
Was dit antwoord nuttig?
1 Opmerking:
Ive already tried that. Im just trying to figure out why it only boots when its hot
door
Voeg je antwoord toe
Ethan Leroux zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 2,804
