Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 keeps searching signal, faulty u_qpoet?
Hi guys, I have an iPhone 6 here. The phone has signal issue, keeps searching. In the settings the ICCID, IMEI and Baseband are all present. Upon testing, I found no voltage detected on VPA_APT line. I know VPA_APT line is powered by U_QPOET chip, so I replaced the U_QPOET chip, unfortunately it made no difference, still no voltage on VPA_APT, phone still has no signal. I also tested the coils L4001_RF and L4002_RF, they both have 3.9V, which I think is normal. I don’t know where to go next. Any help would be appreciated!
Is dit een goede vraag?
2 opmerkingen
Do you also get IMEI displayed when typing *#06# in dialer? That grabs the IMEI straight from the baseband chip.
There's some pretty good info from this thread:
Constant searching, no signal..
door
Hi Ben, before replacing U_QPOET, yes IMEI came up when dialing *#06#. To be more specific, before replacing U_QPOET, the phone showed “no service”. But after replacing U_QPOET, the phone showed “searching”, no IMEI came up when dialing *#06#. I installed the U_QPOET twice, made no difference. :(
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Interesting as I found a nearly identical question from last June on Jessa’s forum. The OP said that doing the U1/V1 jumpers solved the problem.
For the original No Service error, I would focus on the ASM/WTR and WFR. In one case, I found that the top layer of the ASM had shifted and reflowing it solved the issue. You should also fully probe the BBPMU.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Without the background to the device im kinda thinking that it may be liquid damage?
I would check that the line you mention against a known good board and make comparison.
Then i would check PM8019
Score 1
2 opmerkingen:
Hi, thanks for your reply. The phone is not liquid damaged. The board is clean. On a known good board 3.7 volatage is detected on VPA_APT line.
You mentioned the baseband PMU might have problem. I wonder, VPA_APT gets power from U_QPOET chip, how come will a faulty baseband PMU affect the VPA_APT?
door
No problem!
VPA_APT doesn't get power from PMU if you're not getting a reading from it you will need to follow that line and see what it connects to.
I would check zxw if you have, if not let me know I'll post a screen shot when I get back into work.
door
bro you only needed to replace C4005_RF that’s the main problem! I have fixed this lots of times already is due to low power on the Cap
Voeg je antwoord toe
phonestore.uk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 813
