Ga door naar hoofdinhoud
Sony Xperia M4 aqua was released 2015, June. With a Size of 5.0 inches, it was operated in Android OS, v5.0.1. Sony Xperia m4 Aqua has internal of both 8 GB, 2 GB RAM/ 16 GB (E2306) And it has 13 MP Primary Camera and a 5MP Secondary Camera. This phone has a non-removable Li-Ion 2400 mAh battery.
20 Vragen Bekijk alle
Exceptionally Slow and easily overheated.
My phone is exceptionally slow with all applications, phone calls, whatsapp chats, texts and calls and most times gets uneccessarily heated and goes off mid action. What is the cause of this? I have taken this to a registered phones repair centre who have also been unable to resolve the issue.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Try starting the phone in safe mode and check its’ performance.
It it works OK in safe mode then a downloaded app is the cause of the problem.
The trick is to find out which one. You’ll need to uninstall each downloaded app,one by one, and test the phone between each uninstall to check its’ performance. When it does start to perform normally then the last downloaded app that you uninstalled is the culprit.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
aso_madichie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 190
