Replaced Battery, phone has no service and is constantly "searching"
My phone was working perfectly except that the battery life was bad. I had replaced the battery before and figured what could go wrong by doing it again. I followed the ifixit steps and used ifixit parts. I had some minor trouble getting the old battery out but I thought everything went smooth. I turned on the phone and everything seemed fine.
After a bit, I lost cell service. My phone displayed “Searching” and if it wasn’t showing that it showed “No Service”. Everything else on the phone worked fine.
I attempting a reset by holding the power and home buttons until the apple logo appeared. This got the signal back, but only for a bit, then it went back to “Searching”
I then tried doing a reset of the cellular network. This also helped for a bit, but ultimately the phone went back to “Searching”
I then tried taking out the SIM card, blowing in the slot, taping down the SIM card but none of these methods provided better results.
I opened up the phone again to see if there was any damage I might had done near the sim card on the logic board, but the phone looked fine…I closed it back up and got service again only to lose it after a few minutes.
Unfortunately, my phone seems to be getting worse after the second opening. My phone now had turned off randomly (even just while sitting on a desk untouched) and then once I touch it to attempt to use it, the apple logo appears and it boots back up. Additionally, the WiFi won’t be used when I initially use the phone. Only after a few seconds does it come back on and get signal. This isn’t every time, rather more sporadic for both situations.
I have no idea what I might have done or did do. Besides these random on off and WiFi patches, the only thing that is wrong with the phone is the cell signal. Please help!!!
Edit: My phone now will barely stay on, keeps resetting even when just sitting on a desk, it will reset over and over again, each time after a few minutes. This all while still having the problems above. Please help before my phone becomes a brick!
Edit 2: Followed the steps that were provided below but still have the “Searching” problem. Unsure if the resetting problem was fixed from this but so far so good in that regard.
Is dit een goede vraag?
