Ga door naar hoofdinhoud
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 Vragen Bekijk alle
iMac EMC2805 Logic Board Replacement
I have a 21.5” iMac Mid 2014 A1418 with logic Board 820-4668-A which is faulty.
Looking for any alternative logic board I can use which will work in this system.
Also one that can support upgradable memory and/or blade SSD supporting logic board.
Is dit een goede vraag?
1 Opmerking
Were you able to find an alternative compatible logicboard? Or were u stuck having to replace with the same one?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I found a 1.4 GHz Logic Board that supports a blade style SSD on an external site (iFixit is sold out) but you are limited to 8 GB of RAM because it is soldered to the Logic Board. I did a pretty widespread search but found no compatible Logic Board that you can upgrade the RAM on. You will need to replace the display adhesive strips and I have included a link to buy them below too.
http://www.dvwarehouse.com/661-00148-App...
[gekoppeld product ontbreekt of is uitgeschakeld: IF173-005]
iMac Intel 21.5" EMC 2805 Vervanging van het moederbord
iMac Intel 21.5" EMC 2805 Vervanging van de blade SSD
iMac Intel 21.5" EMC 2805 Moederbord Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
iMac Intel 21.5" EMC 2805 Blade SSD Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 1 hour
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thankd for the answer is this model has any fixing issues on iMac cabin
door
Hold on! @ajcooke01 - The logic board you pointed to has fixed RAM and does not offer SSD support!
@rajiv8047 - Lets find a better board!
door
@danj you aren’t going to get much better then fixed RAM, the one I just updated the link to has SSD support.
door
Voeg je antwoord toe
Rajeev zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 185
