Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
iPad Air Wi-Fi + Cellular, modelnummer A1475. Verkrijgbaar in Spacegrijs of Zilver, met 16/32/64/128 GB configuraties.
Problem with screen replacement
Afbeelding
I have tried replace the screen to my ipad and it appears to be like in the photo. Can anyone tell me what’s wrong with it? Is the LCD broken and spoiled? How do I fix it?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
That looks like pry damage on the LCD or bending the display cable on it too much, you’ll need to replace the LCD display.
Since you’ll need to open it up again I recommend buying another replacement glass touch digitizer as well as it is easy to crack replacement glass when you need to open it up again.
I have provided guide and parts for a replacement LCD display if required:
iPad Air LCD
iPad Air LTE LCD vervangen
Replace a 9.7" LCD Panel compatible with the 1st Generation A1474 and A1475 model iPad Air tablet. Part #821-1824. Afbeelding
Product
iPad Air LCD
$79.99
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
I haven't opened the digitizer glue, so i guess there is no need to open and buy a new digitizer? i also have followed the instructions closely, i just want to know what causes the damage. im so sorry. please help me.
door Deel
if i just connect the lcd cable without the digitizer, will it work? i want to check if the digitizer is the source of the problem.
door Deel
It will work without the digitizer plugged in but you need to be careful when disconnecting and connecting the LCD display.
Make sure the battery connector is lifted as shown in the guide when doing so before powering it on and you'll have to power it down using the lift up battery method while the screen is off.
I suppose a possible cause is damage on the display ribbon cable itself if it touches the housing or is scraped.
door Deel
if i dont have the battery isolation pick, how should i do it? should i just unscrew it? thanks!
door Deel
What I usually do is take out the battery screw and lift up the battery connector with your nail. You can use any non conductive plastic tool to provide a spacer between the battery connector and the battery to make sure it doesn't connect.
To confirm the battery is disconnected. Try powering it on without disconnecting the LCD display cable, if it doesn't it's ready to be unplugged.
door Deel
Voeg je antwoord toe
tikus belon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 46
Altijd: 721
