Ga door naar hoofdinhoud
The ATI Radeon X1900 XTX is a high-end graphics card from 2006.
1 Vragen Bekijk alle
How to repair a deadly graphics card
How to repair deadly graphics card
Is dit een goede vraag?
1 Opmerking
Hi Anmol tech
what do you mean? when you connect, what do you observe when you test the graphic card....
artifacts?
no display?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You don’t say what’s wrong with it or what you have tried. Is its presence recognised by Windows? Was it previously working but then failed, or is it one you’re trying to install? Does it work in a different machine? If it’s recognised, check for any available driver updates. Is your power supply sufficiently powerful to drive it?
Make sure the fan isn’t clogged with dust and is spinning freely when the card is powered up. Check that the gold fingers on the connector are clean an undamaged, and similarly the socket it plugs into. If it’s actually faulty then there’s probably not much in it which is repairable, realistically speaking.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Anmol tech zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 295
