Canon Rebel T3I won’t turn on with SD Card inserted
My T3I won’t turn on with 64 gb Sandisk 100 speed SD card inserted. It would be working fine until I insert the card then it’ll shut off and won’t cut back on until I take out the battery and put it back in without the SD card inserted. Any help??
Is dit een goede vraag?
1 Opmerking:
Hi T Svpreme,
Had you tried with another card? inspect the SD card slot and door for any debris.
I heard from a camera service center @ canon, if the SD card door has issues e.g. not closing properly or micro switch sensor does not capture... it can cause the camera not to turn on.
door
Voeg een opmerking toe
